msfamilia said:On the track, these are very predictable but not grippy enough for my taste.
I drive on a very aggressive alignment on the track and with the unmatch front rear tire pressure, the rear wheels are meant to "walk out" a little in turns to eliminate most of the understeer. However, these tires do not have enough grip when heated so my rear goes out too much that it now requires a lot of corrections.
xelderx said:Are you running more pressure in the rear or less? Running more will cause more snap oversteer and running less will cause a more progressive breakaway.
