Halogen Headlight Assembly replacement with Xenon
adihan
Mazda CX-9 Touring 2008
I have a CX-9, the passenger side halogen light got damaged and to test things I purchased a Xenon assembly, it was a good deal, I would like to replace the driver side too with the Xenon assembly. It seems that the wiring harness is missing the connector for the ballast HID control unit. The wiring has the standard plug for the headlight assembly, but on the Xenon light, the ballast unit needs its own power (has a small female plug) and not sure if is pre-wired and all I need is to find the plug and a connector cable or I am missing the wiring all together.
Thanks.
