Guide to replacing spark plugs
View attachment Spark Plug Replacement Overview.pdf
View attachment Ignition Coil Removal.pdf
View attachment Intake Manifold Removal.pdf
Here are instructions for replacing spark plugs. See the overview first, and then the coil removal and the manifold removal.
The "before" cautions not attached basically say to remove the fuel filler cap to release any fuel pressure in the line or else you could blow yourself up on accident when working in the engine bay.
The "after" cautions not attached basically say to make sure when you're done working in an engine bay to double check that there are not fuel leaks or the same thing could happen. lol.
