Got some mail today...
and how many threads do you have before you go all the way down in the back, like before you take out the purches? and same for the front, what are you runnning?
Im pretty sure its not the highest setting.
Wasnt there for install so im unaware of the remaining threads, but when I go to adjust in a few weeks ill know
Very comfortable and controlled. Not bouncy at all. Speed bumps are very manageable.... Until I go lower :)
do you have a lesser amount of body roll on corners?, like i know this is a no duh question but can you feel it
take some sharp turns fast enough that the back wheels squeel a little thats the rear sway, and if you like "tested" it like going around the turn at different speeds before and after the coils, then you could prob feel the difference i guess? but since you have em on idk lol
Are those 18s? My car looks the same in the rear your front is a little lower than mine. By the way hows your rear is the right side same height as the left side? Im at the lowest on my KW v2s and the right side is actually a bit higher than the other side its not really noticeable but when you look closely the right side is a bit higher.
actually just saw iheartmyhatchie at the meet this weekend. reason he looks slightly lower in the rear than garret2331 is because he has the rear perches removed.
yeah he told me over at mocc forums, he said he had them removed and he thinks they are not good for the shocks too.
I just can't think of why the rear right side is a little higher than the left side. Ihartmyhatchie said he has same issue.
The first thing i'd do is make sure the springs are both seated correctly.
