- 2002 Honda S2000
not bad considering an alignment alone can easily cost $70-$100. basically the install is costing you about $300. like i said, my friend paid $250...
More.What are the stock specs? -1.0 in the rear?
More.
http://www.mazdas247.com/forum/showpost.php?p=3231136&postcount=4
Hey Zach, in your sig, at that height, are you rubbing in the front?
That's a bummer... 379 is terrible with an alignment... Compared to Hugh's or Gramps' prices. 100-150 for install plus 80 bucks for an alignment shop sounds much more reasonable.Edit: bad news... for the mocc guy.
My dad doesn't want me driving down to long beach, and he doesnt trust people off the internet. So hes making me go to a shop.
Does $379 WITH alignment sound like a lot?
interesting. well, according to this the info i have is slightly off. rear camber range on full tank is -.42/-2.42. which means i'm just outside of the recommended range.
no rubbing in front except for sometimes at full lock turn. the rears are what i had to work on...
iheartmyhatchie has KW V1's
yea im 17 also.
Shane did the package come with only one hook wrench? Im not sure if mine came only with one.
Are those 18s? My car looks the same in the rear your front is a little lower than mine. By the way hows your rear is the right side same height as the left side? Im at the lowest on my KW v2s and the right side is actually a bit higher than the other side its not really noticeable but when you look closely the right side is a bit higher.
