i stopped by a local shop today(Agile Automotie Performance) and talked to them about a custom front mount for my car, they quoted me 1400.00 total 1200 for parts and 200 for labor, does that sound about right?
that depends on what core they're setting you up with. i think cashmere did his own for way less.... and I've thought about doing my own.
why spend 1400$ when you can get Begi engineering from ken at protegegarage for like 950$, and its got a warranty from a real company?
im not 100% sure on the core size i think he said like a 400 or a 500 maybe im not sure does that sound about right??
Will the begi kit work with my MS Intake?
or just go with the ets TMIC
i can see your point on that. this is just through stuff i have heard, i have never looked into it that much, but i have heard on this board that a fmic will actually loose pressure because of the amount of piping that the air is required to run through. Personally my thoughts are that if it is a sealed system then you can't loose pressure. or can you? if the same cfm of air is being put through an area with more space, wouldn't that decrease pressure right there? its kind of like water. if you put the same amount of water through a fire hose wouldn't there be less pressure than if that same amount was going through a garden hose?
i made my own FMIC, CAI, and got a $300 BOV for about $900 total spent. That includes welding gas ($90 argon/co2), lunch trips, clamps, silicone, core, bolts, piping, etc...
$1400... they are ripping you for sure.
parts, MAYBE RETAIL about $500-600. Labor will be the expensive thing. Between me and 2 buddies, took about 18-20 hours. Started from completely scratch.
$1400 for FMIC, no way. I would wait for Cobb's if i were you.
Where does the hot air go directly after it passes through the intercooler ? yup, ur right, right on top of the engine.
Doesn't matter what a TMIC looks like, because you are just going to put the plastic cover back over it. If not, it will not work efficiently...
