shh u. i welcome the help.
Im most likely doing a 1 piece. doing it seperate would make it just like the CS one and while i havent had an issue with mine, id like to avoid using alot of pieces.
whatever is cheaper for me. I want a 3incher.
which is better, do you know or will you know of a place to get a cheap cat for this?
I ask cuz I have a catless dp on the side not on the car apexr1.
But what I have on now is a hiboost 2.5j-pipe which connects to the stock 2 bolt s*** then theres the stock cat, the sensor and after the sensor the exhaust is cut off and theres no piping at all no axle back no muffler. Exhaust ends at the front doors.
So I just wanna know ahead of time what cat would be the best and what material your gonna use since I'm gonna have to remake this part, and someone is gonna have to weld and ad the cat etc. ???
no I know it's not a part of the downpipe and where yours is going to end I understood that. The apex one is just long I was just saying that I'm not trying to go catless with your dp.
I guess wouldnt it be easier to eliminate a flange all together then at the end at least for me?
cuz if there was no flange, then another 3in pipe could be welded to the end of your s+j-pipe, then a cat, then I'd make a hole for the sensor. And the hangers hold up the pipe obviously.
yea I want no flange if it's cool.
