Cost:$515(Bay Area, CA)
After reviewing sheet they had and doublechecking with the tech, they pretty much replace all fluids which is what I wanted. I was doubtful that they did but sheet said they replace and not just top off.
Oil
Transmission
Brake
Coolant
along with the following:
Power steering fluid(top off only)
Cabin and engine air filter
Tighten all bolts
Lube hinges etc
Rotate tires
Check suspension
Check brakes
Idle etc
Spark plug replacement only done at 75k so not necessary at 30k and 60k service they said. Similar pricing elsewhere? I used to DYI but no longer have time to do any of that plus I read somewhere on here that some of these are required to honor some warranties down the line. Btw I got a 2010 3 sedan as a loaner, not bad for daily driver.
Oil
Transmission
Brake
Coolant
Tighten all bolts
Lube hinges etc
Rotate tires
Check suspension
Check brakes
Idle etc
