gasket maker to reduce interior panel vibration ?
for what its worth, mazda uses little felt pads in between the panels for vibration abatement. if you ever have to remove any of the panels, gasket sealer (RTV, i assume?) will not be a good choice.
i mean the plastic panels
was thinking about using the rubber like paste (left over from last valve cover gasket change)
i just brought some 3/16 and 1/4 thick foam tape, hope it will absorb some of the vibration.
