Maybe I understand this differently than you...
"Drive is through Mazdas advanced Active Torque-Split All-Wheel Drive system, which uses various sensors to signal control modules that automatically apportion torque to those wheels most able to provide solid traction. A computer-controlled coupling, connected with the rear differential, automatically adjusts the torque distribution, allowing up to 50-percent of the drive power to be sent to the rear wheels, depending on traction conditions. This all-wheel drive system is also used in the Mazda6 MPS and CX-7." (source)
and
"Vehicle safety starts with those four crucial 'contact patches' where your tires touch the ground. So to help provide optimum traction, regardless of weather or road surface, every Mazda CX-7 is available with Active Torque Split All-Wheel Drive. This advanced, computer-controlled, all-wheel-drive (AWD) system continuously monitors wheel speed, Anti-lock Braking System and Dynamic Stability Control operations as well as engine data, to distribute the optimal amount of torque between the front and rear wheels from 100:0 to 50:50." (source)
Also, TCS controls engine torque by lowering it when the system detects wheel slippage, helping them not to spin. It's very simply explained in the manual on page 5-22. I have no confusion over the difference between TCS and an AWD systems that isn't providing 50:50 torque full-time. 100:0 to me mean front wheel drive until conditions call for a different ratio of front-wheel to rear-wheel torque.
and
