Funkalicious21's Protege5 Build/Progress Thread~!
Is that coating baked on or something? It looks like it's chipped away from the water pump housing. I would just be worried it would chip and get in the cooling and oil systems.
The colors look pretty sweet though. :)
Signature Soundsome critical parts showed up. BIG thanks to Noah at AAC for setting up the group buy and making this easy. The complete kit is outstanding quality. The rear kit will also be available.
Dual master cylinders. balance valve, massive rotors, braided lines... top notch stuff here. Contact Noah today to get yours: AAC@agressiveautoculture.com
haha nice! thanks for the props and for photographing the parts. stoked to see them in a high caliber build!
My lawd, I can't wait to see this car when it's done. I wish I lived closer to CA so I could see it in person. (2thumbs)
*Signature Sound*here is a breakdown of what goes into each bracket and external part bolted to the motor. about 8 batches worth thru the oven with misc small parts and still not done...
how a typical part begins without any coating on it
first the prep with an angle air sander to get rid of unwanted roughness and to smooth it all out
then degreased, sand blasted and chemically washed, then heat dried in oven to drive out all remaining contaminants
then chrome base color is applied and black chrome clear is put on over that
motor mount
t-stat housing and pipes (pipes were done in satin black)
hiding the CKP wire
knock sensor for J&S mounted. Helicoiled to fit 8mm x 1.25 thread.
oil feed tee adapter installed & turbo mounted and ready to go in.
*Signature Sound*
transmission will be getting coated next weekend
next the motor was placed in the bay to mock it up to see what holes can be welded shut.
*Signature Sound*and then had just enough time to put the big brake kit on to find out the current wheels hit the caliper...
Latest posts
