Fujita CAI
MS64U2NV
06 MS6
Is this CAI any good? I got a really good deal on it, but the more I look at some of the other MS6's online, it doesn't seem that anyone else has one (probablly why it was cheap). Am i going to have a problem with it as well when it rains. Heard that too. Not using to driving a sports car, always had an SUV. Any inputs would be helpful. Thanks all.
we have sold a ton of these. not a bad intake at all. where you are at in AZ you should not encounter problems with the intake. only in absolutely torrential downpours, and even then thats debatable, or if you submerge the front end will there ever be a potential for concern. otherwise you will enjoy the intake.
I have the Fujita intake and have great result with the CP-E Standback .
Put the Injen hydroshield and you will stay away from hydrolock problem .
Ok, so now I need some help. I installed the intake no problem. Well thats a lie there were a ton of issues, but thats not the case. The problem now is, wierdest thing, the power windows don't work. On the drivers side I can use my window, but no others. and the other ones only work from their own switch. Anyone know what the problem might be?
My english is not good but i will try , your problem is normal , you need to roll down each window and roll UP each window ( with each button) and keep the button up for 3 second you will hear a little clic clic in the door , after that the window will be fine , each time your take off the battery you will need to reprograming the windows . Sorry for my bad language , hope this help .
Thanks for the advice man that worked out real good. Just went out and did that and problem was fixed. Never would have thought that would be the problem.
read the sticky at the top of the welcome section...
