Also, if you are boosted, make sure you are not boosting the gas tank due to lack of a one-way check valve. I had that issue, and it was putting a fuel smell out..
i know its an old thread but just wondering what you found out. im getting a leak from the top of the tank around the fuel pump area but havent determined if its the return line or a seal around the top of the pump
