- ‘19 CX-5 GTR Tu
Excerpt from yourmechanic.com
A sulfuric or rotten eggs smell indicates an excess of byproducts left over from failed combustion. Removing the smell requires part replacement.
The byproducts and deposits causing the smell are left over from the incomplete combustion of gasoline being burned and can be traced to multiple system failures. Should the smell only occur briefly after using the engine at high revs, there is no serious issue to be concerned about. A lingering sulfur smell, however, needs to be investigated. Listed below are 3 reasons your car smells like sulfur.
