Fuel pressure regulator
Mazda, Mazda5 Sport 2013
Could someone tell me where to locate this item on a 2013 Mazda 5 Sport, may need to replace as i am getting slight hesitation starting the Mazda, runs fine afterward. Thank you. Is there a video about this as well?
Is there one?
I thought most cars just have a fuel pump that puts out a set pressure. It's up to the injectors to regulate the gas into the engine.
I'm thinking you need to replace the pump.
My wife is reporting the same symptoms; a few seconds of cranking before finally starting and runs fine afterward. So far it has only happened when sitting outside, but doesn't seem to be dependant on weather. 🤷‍♂️
Curious what you've tried, Freerojo.
