FS parts in the FP
Rubberspoiler
'99 323 FP-DE
After reading on wiki (?!) that putting FP pistons in the FS, you get the compression ratio of the FP (9.7:1). It is said that both engines have 83 mm bore. So wouldn't that make it possible for me to use the high compression pistons for the FS in my FP-DE (the 10.7:1 pistons)????
Can anyone verify or dismiss this idea???
Thanks
Niels
yes you can use the FS-ZE pistons but the compression will be a bit less then advertised
But why is it, that the FS would get the 9.7-1 compression with FP pistons, but FP won't get the high compression, with the FS high-compression pistons??
And would would I get by using them in my FP-DE?? (the 10.7-1 pistons I mean)
Thanks
Niels
