The front windows in our '08 give out a quick chatter when you initially begin rolling them down almost as if the window regulator cables are loose and it has to take out the slack before the window actually begins moving. This occurs when the window is in any position...even all the way up. The car is at the dealer right now for the rear bushing tsb so I had them check out the windows as well. They said they pulled the interior panels and noticed that there is some looseness, but that it's nothing out of the ordinary. The rear windows are solid and smooth.
Has anyone else experienced this? I ran across this tsb for the MPV and it seems rather similar.
http://www.mpvclub.com/tsb.php?id=27
