Front suspension noise; need help identifying problem
Either the sway bar end links (cheap and easy to replace), or most likely the sway bar bushings (cheap but more difficult to replace).
New shocks, especially high performance ones, make the symptoms worse.
I've isolated my issue to the sway bar bushings, and will be replacing them soon.
I have the Cobb bars and bushings, so they "should" be more durable than the stock rubber ones. I'll have to crawl under there when I replace my rotors next month.
Sway bar bushings are still a wear item, and aftermarket poly bushings should be greased. I don't know what material Cobb uses, but IIRC the bushings have grease fittings.
