mhrebin said:you will feel the front end stiffen up a good amount. taking turns feels better and it helps alot.
oooo i like the sound of this cant wait now.
i have another question. if u install lowering springs will that have a negative effect on anyother suspension part of my car
illogik said:It's a great mod to tighten up the front end and even better if you've done a suspension upgrade.
I've got a pdf copy of the install instructions if you want.
ye Man id really like to take a look at them if u wouldnt mind
sephiroth said:If you've got cruise control, you'll need the mounting hardware anyway, but a lot of people swear by using an aftermarket strut bar instead of the stock one. Since the stock bar does stiffen up the front by a lot vs none at all, but it still does flex quiet a bit vs something like a GT spec bar.
krisl_29 said:I never noticed the difference until I took it off, a lot less control during turning
jeg0024 said:Your selling one arent you? Did you get something else instead?
krisl_29 said:No, just need the money, but I think I'm going to put it back, now that I felt the difference...
jomoyo069 said:whre do u get the cruise control brackets from? how much are they?
