Front parking lights don't come on
Lucius
2012 Mazda 3
Hello,
On my 06 CX9 the front parking lights don't come on when I turn on my headlights or turn on the parking lights. When I turn on the emergency flashers they flash so I know the bulbs are working. I didn't see any fuses out. Does someone know what the trick is to get these lights to come on?
Thanks,
Luke
The flasher will work off a different element in the bulb.
I'm not sure which fuse will control them though.
^Yup, the parking lights and turn signals are different bulbs. Check your fuse panel or owners manual for what controls the parking lights and check that fuse. On newer models those "parking lights" are the same as the daytime running lights.
I had the same problem and it turned out that both bulbs were burnt out. I replaced them; and bam! They worked :)
