strongbear0
MS MSP said:The front one you can do yourself in 10-20 minutes with the right tools.
The rear one invloves a lot of blood, sweat, tears, and time or a trip to the dealer/garage.
With the right tools and knowledge the rear can be done in about two hours. After you remove the wiring loom from the bracket that holds it you will need to remove the plastic bracket that is held in by two 10mm nuts. After you remove the bracket that holds the wiring loom in place you will be able to get to the two back nuts on the mount. You will need a rachet with a couple of long extensions and a swivel joint to get to two of the bolts on the rear mount, due to the angle you have to get to them at. Once the three nuts are taken off of the mount you can remove the threw bolt and wiggle out the old mount and manuver the new one in there and put all of it back together. This process is much easier if you take off your cold pipe, it gives you a lot more room to work in there. It is still a very tight fit though. This installation is not for the mechanically inept, I would have to say it was the hardest thing I have done to date on the speed. Even harder than installing my perrin fmic, it didn't take as long but it was harder.
