RedBaron
2014 & 2019 CX-5 Touring(s), 2023 CX-50 TPP
I was thinking the same thing!To me they look like stripped threads.
You are likely 100% correct.I'm 80% sure those are not helicoils.
I've seen similar coils when doing torque-to-failures tests for mounting brackets.
I'd say the previous person over torqued and/or cross threaded them.
Thanks for the info. Ended up getting the caliper kit from Napa (dealership and Napa only sell the full kit, not solo bracket) for $125 CDN plus $50 core deposit. Didn't replace caliper as it was perfectly fine, so now I have a spareIt definitely seems like whoever did the previous brake work messed up. My first guess is that it was a teaching moment for a new tech, who mistakenly removed the caliper bracket bolts instead of the caliper slide pin bolts and then screwed up reinstalling them, leading to the rounded threads on the bracket. Then, they decided to use helicoils to hide their mistake and hope you or anyone else at the dealership never found out.
At this point, if you have the time, it might be a good idea to find out what a local junkyard would charge for the caliper brackets if you were to pull them from a junked turbo CX-5 yourself. Or, instead of ordering from a local dealer, consider ordering from an online OEM Mazda parts store, like the mazdaswag.com link that @Silly Wabbit posted above. It's $100 CDN for a new OEM part, but not sure what the shipping time or cost might be. Partsouq.com would be another option, but they do not have stock for that part.
Palladino Mazda is Canadian, they have the part listed for $160 CDN but that doesn't include shipping.
To clarify my earlier post: the second dealer at my 48k scheduled maintenance did not do the brake service, likely only a visual inspection to say it was time to replace pads/rotors, so no point in doing / charging me for the brake service if they soon needed to be replaced.I'll throw my .02 cents in .... If there were only two dealers that ever worked on the brakes, it's the second that messed it up. If it was the first, the second mechanic would have pointed the problem out to you so they don't get blamed for it.
