Front end issues
Amanda
02 Mazda Protege 5
So I started getting a squeeling noise from my front end (wheel well) figured it was just my breaks. Pulled the tires off and the pads were fine. Now only my passenger side is turning when it's in drive and the drivers side is locked up. My emerg brake, ABS, and O/D lights are on now. any suggestions.
Sounds like a seized caliper.
The ABS light might be related, you can get a better idea if you get the ABS code (see the service manual, there's a procedure to get the codes without a pricey scanner). The parking brake light seems to come on when there's an ABS problem so don't worry about that.
