From Xenon to Halogen headlight assembly (2013 CX-5)
Hello. I have a 2013 mazda cx-5. I'm currently desiring to remove the xenon hid D4s bulb and the entire headlights assembly. I Would love to replace that assembly with the halogen headlight assembly And led bulbs.
Is there a kit to be purchased? Or, is there any instructions on how to convert the wiring?
If you do a Google search for "HID to LED conversion", you'll find many, many options to do just that. However, I would strongly recommend against LEDs in a headlight housing meant for halogen lighting. LED bulbs are typically brighter, and more focused, so when they're installed in a halogen headlight, the reflectors shine light where they shouldn't, and the result is that the light becomes blinding to oncoming traffic.
If you do this conversion, ensure you get the correct bulbs, and that they are aimed properly. Additionally, since you're dealing with wiring, I would stay away from the AliExpress cheapo options to reduce the risk of damage from low quality construction.
