Forged rods & stock pistons
2.0t03speed
08.5 CWP Speed 3
hey guys i was wondering if anyone has done forged rods w/ stock pistons. i know that the pistons would have to be machined to accept the wristpin but is that it? if so i was wondering how much power you made before the stock pistons went. i really just want to max out the stock gt25r have around 250-270 and call it a day but i want to have peace of mind when i do it, hence this thread. any help or info you could give me would be appriciated
you can make it work. talk to igdrasil (sp?) or juan at hiboost about it. however, if your going to all the trouble to repace the rods, y not spend a little more and replace the pistons as well?
subbing, planing on going this route too.
if able to do it...what RODS would you use?
and also, you planning on using NEW pistons or reusing the originals....
thnx
because im not looking to make that much power just between 250-270
if you are going to go through all the trouble of pulling the engine and doing any type of machine work, you oughta just get a set of pistons and not have to worry about them being a weak link.
dude, is enough labor and money for some of us to replace that. and it has been said that the pistons are good, the bad thing are the rods.
maybe we won't get away with low compression...but we'll be forged. i'll be happy making 270whp. that's all i want anyways
+1. budget is real tight, and if it's not necessary to replace the pistons, and cheaper to just leave them be, then goodnight.
if not replacing the pistons, then maybe, JUST MAYBE there won't be any need to machine the block, if you do a pressure test and it come out good.
maybe just replace the rings..
i know juan does it but it costs more than new pistons and rods (think is was 12-1400) so i dont really see the benefit when u can get stock bore pistons now (im assuming thats the idea so u dont have to machine the block). u can get k1 and weisco for less or equal and its going to be plenty for 300. you do have to machine it to accept the floating wristpin. i dont know if theres any more work to do. if ur doin the labor urself then i can see the savings and it would be worth it, but if ur doin it turnkey id just get all new stuff in stock bore size (as long as ur block is ok to hone)
what you say does make sense.
i would've figured it was less expensive, but i can see why they'll be more expenisve..is not just a matter of taking a drill and making a bigger hole.
good point.
good point.
i know ;)
i actually looked into it myself. i think he started doing it back in the day when we didnt have many choices. in that respect it was a novel idea. but now, as i mentioned we have stock bore pistsons so unless u do the work urself your not really saving.
yea i see what your saying but the price will be the deciding factor for me im going to go price how much it would be to machine the piston to accept the wristpin hopefully i can get it done for free seeing as my bestfriend works at a machine shop
I dunno about you, but i'd rather have someone who's doing it for the money. They'll be more interested in giving you a quality product. you are talking about machining the heart of an engine...something is misaligned for just 1 mm and you whole thing could go to hell
not always how many stories have you heard about ppl paying a huge chunk of money and not getting s***/s*** quality. but i see what your saying
if ur gonna have ur friend do it i would get a garentee in writing cause if they fall apart u could ruin the whole block / turbo etc. im sure this will be his 1st set of pistons doing this to so u dont really have the resources to do trial and error since ur on a budget. id feel better if u saved up for the right parts so u at least know its made for each other but thats all up to u.
