yep you heard right a forge WGA is on its way. i spent most of Thursday at PROTEGE GARAGE doing the prototype install of a sweet fully adjustable actuator. it has interchangeble springs and rod preload adjustment. the install is not too bad. we did have to remove the turbo inlet tube to get good clear access to the bolts, but that wasnt too bad. my goal is to run my desired boost WITH NO BOOST CONTROLER. with the right combination of spring and preload it should be possible with this WGA. we did the install with the blue spring which is rated at 13-18psi, and very little preload. with that and no MBC i am seeing spikes to 17psi and holding 14. yes that is low, but i have yet to make any adjustments. i think with the blue spring i should be able to sial in a 20-21psi spike and hold 18psi. if you want more you can always add the MBC or step up to the red spring (20+psi). the stock WGA is set to 8psi, so even the blue spring at the lowest 13psi setting is an improvement. the spool up is WICKED fast, i'm just not boosting it high right now. the weather has been s*** lately so i didnt bother tweeking it, since i couldnt go out and womp on it anyways. this thing is really sweet. DONT GO CALLING anybody to order it yet cuz it isnt ready. the bracket i was given to mount it didnt work. they wanted me to try that bracket since it was from another model they already produced, it needed some "massaging" but we got it to work. all in all it will be ready for the rest of you soon, and i will post my final review of it once i get it dialed in properly.
i also want to give a big thanks to FORGE for taking the time to make another kick ass product for us mazdaspeeders.
and dont forget my fellas KEN, ZACH, and ARIC at PG for helping out with the install !
P.S. when i first installed it, i left the MBC on just turned slightly down from where i had it. i think i owe ZACH a pair of new undies !! on the test run the car spiked to 26psi and held 20 psi past 6k rpm !!
maybe one of the PG guys can post the pics we took, i didnt have my camera.
