Thought I should share this here just for reference. Below is the official response I got from Redline in regards to LSD noise after switching to MT90 and adding Friction Modifier to reduce the noise:
Below are the results from the Red Line Oil web site Application Request Form.
It was placed on 12/11/2008 10:25:47 PM.
Application Request Form Information
Email Address : -----------------
Address : ------------------
Address 2:
City : --------
State : ---
Zip : -------
Make : Mazda
Model : Mazdaspeed3
Year : 2007
Engine Type : 4 cylinder turbo direct injected
Differential Size/Type : Torsen Cone Type Super LSD
Transmission Type: 6-speed transaxle
Issues : I've recently replaced the transmission fluid with MT90 which is recommended for my vehicle. However, I'm experiencing LSD noise under low gear low speed tight turning in cold operating temperature. The transmission is shifting perfectly smooth under all condition. The only problem I have is the LSD noise after switching to MT90. I understanding your company makes a friction modifier that can be used with the MT90. What are the effects of adding friction modifiers to the MT90? Will it eliminate the LSD noise at the expense of shifting quality? If I choose to add the friction modifier, what ratio of mixture is appropriate for my application? If I choose NOT to add the friction modifier, will the LSD be damaged or its longevity shortened due to the noise? What is your recommendation in regards to whether or not to add the friction modifier?
)EIB(,
Thank you for contacting Red Line Oil, the cone type limited slip units are generally not particularly prone to chatter. The Friction Modifier can be added to the MT-90 though too much will be detrimental to the shiftability. If you wanted to add some I wouldn't exceed about 1% by volume, less than an ounce. The chatter is more of an annoyance than being harmful, I wouldn't expect it to affect the life. If the noise isn't annoying, then I would just live with it, if too annoying then I would increase the slipperiness of the fluid slightly, you could decide that.
Regards, Dave
Red Line Oil
After receiving this response, I decided not to add the friction modifier and just live with the noise.
Address 2:
City : --------
State : ---
Zip : -------
Make : Mazda
Model : Mazdaspeed3
Year : 2007
)EIB(,
Regards, Dave
Red Line Oil
