LittleRedWagon5
- 2008 Mazdaspeed 3
$600.00
ONLY 1 YEAR OLD.
was in my Protege 5 before i sold it.
has remote and all cables and wires.
1 cable slightly damaged from removal, but still works, just missing plastic cover.
7.0 inch Wide Colour TFT Active Matrix Display
Number of Pixel: 336;960 pixels
Screen Size: W154.1mm x H87.0mm
New Full-automatic "Z-action"Open/Close Mechanism
Motorized Tilt Angle Adjust (8 Step)
Motorized Back and Forth Display Position Adjust (4 Position)
Interactive Touch Panel Control with New Smooth GUI
Multifunction Key Operation
Audio Easy Control Mode
External Hard-key Operation (When Monitor Closed)
Partial Detachable TDF Panel with DSI & Security Code
Mini Display = 5 x 7 Dot Matrix LCD (Blue/Green/Red)
Selectable Key Illumination (Green/Red)
New Amplifier Control System with '04 PS Amplifiers
EQ(Bass/Treble/Q Factor/Gain Control)
Voltage/Current/Temperature/Fan Speed Display Advanced B.M.S.(Bass Management System) with '02 PS Amplifiers
Wired remote out for original mounted streering wheel remote control
2-way Telephone/Navigation Mute
Digital Clock (24H)
All-in-one Hide-away Black Box ( 5.1ch DSP/ TV Tuner/Receiver) Supplied
Diversity TV Antenna (Window Type) Supplied
Remote Control Unit Supplied
TV Tuner (PAL/ SECAM)
12 TV Station Presets
Auto Memory Entry
SNPS (Station Name Presets)
Maximum Output Power : 50W x 4 + 47W x 1 (for optional Center Channel)
4 Gold Plated Preouts with 5V Pre-output Level (Front/ Rear/ Centre/ Subwoofer)
1 RCA AV Output (PAL or NTSC according to the source)
2 RCA AV Inputs (PAL/NTSC Automatic Selection)
Video 2 Input Signal Automatic Detection Mode (Normal/ AUTO/ Rear View Camera)
Rear View Camera Connection Ready (AV Input-2 only)
RGB Input for optionel Navigation System KNA-DV3200
Dolby Digital/ dts/ MPEG/ Linear PCM Decode
Dolby Pro Logic II (for 2ch Source to 5.1ch surround)
SFC/ 4 Band Parametric EQ/ Digital X'over/Digital Time Alignment
Sound Management System (Type of Car & Speaker Size for Each Channel Selectable)
Dolby Digital DRC (Dynamic Range Control : Wide/ Normal/ Midnight)
SPF (Speaker Protect Filter) Operation
Dual Zone Source & Volume Control
Attenuator(-20dB) with Smooth Volume Return
WMA (Windows Media Audio) Decoder
MP3 Decoder with ID-3 Tag Display
CD Text Ready
CD-R/CD-RW Compatible
Direct Access with Remote
Random/Repeat/Scan Play
DVD Video & DVD Audio Compatible Player
DVD +- R/RW Compatible (Video Format Only)
VCD Compatible
Dual Disc Changer Control Capability (CH1/CH2 & AUX)
DNPS (Disc Name Presets) with Compatible CD Changers
DNPP (Disc Name Preset Play) by Remote
CD Text Ready with Compatible CD Changers
Random/Repeat/Scan Play (Disc/Track)
4 Band parametric equalizer
Band1 frequency: 60/80/100/120/160/200/250 Hz
Band2 frequency: 315/400/500/630/800/1000 Hz
Band3 frequency: 1.25k/1.6k/2k/2.5k/3.15k/4kHz
Band4 frequency: 5k/6.3k/8k/10k/12.5k/16k
Gain -9dB; -7; -5; -2; -1; 0;1;2;3;5;7;9
Q control: 0.25/0.5/1.0/2.0
High pass filter frequency: 60/70/80/90/100/120/150Hz Slope: 12/18/24 dB
Low pass filter frequency: 60/70/80/90/100/120/150Hz Slope: 12/18/24 dB
Channel level: +/-10 dB
FM/MW/LW 24 Station Presets (18FM; 6MW & LW)
RDS with Radio Text
K3i Clear Reception Tuner Circuit
AME (Automatic Memory Entry)
Up/Down Seek Tuning
Local Seek
FM Stereo/Mono Selector
DAB reception with optional unit KTC-9090DAB
ONLY 1 YEAR OLD.
Digital Clock (24H)
Auto Memory Entry
CD Text Ready
VCD Compatible
RDS with Radio Text
Up/Down Seek Tuning
Local Seek
