Fog Light Rewire Nightmare Help Me !!!
SILV3R_MP5
PROTEGE5 2002
I Was Working On My Car And Im Fairly New To Working On Car I Printed A Forum Out On Rewiring Foglights . So I Popped The Side Panal Off Diconnected The Wiring Harness I Cut The Red Wire And Ran A Wire From The Place The Red Wire Was To The Green Wire . It Works Pretty Good The Foglights Work With The High And Low Beans And Know They Also Flash With My Alarm But I Did Have A Problem That I Can Figure Out How To Fix . The Guage Cluster Lights Or Any Of The Light On The Radio Or Air Buttons Dont Light Up . They Only Flash When I Click The Alarm . If U Have Any Idea How To Fix This Please Help Me .
There is a dimmer next to your fog light switch... did you by any change unplug or lower the settings on it ?
Something is very wrong with your keyboard. Makes it hard to read. Since the dash lights up when you hit the alarm, it makes me think you have a wiring mix-up, which is more serious than a blown fuse or dimmer turned down. Best bet is take it to a professional. Best case is the dimmer is turned down, worst case is melted wires and a dash fire.
NA MAN I TRIES THAT LIKE SPENT 3 HOUR RACKING MY BRAIN ON WHY IT HAPPEND. THEN I PUT JUST IT WAS ORIGANALLY IT STILL DIDNT WORK
