Fog light problem, please help ASAP!!!!!
Bebotech
2002 MP5
I have installed hids yellow for fog lights with yellow overlays but, one is darker than the other. If someone has any advise to fix thos issue please help!!!!!
try swapping your ballasts around and see if it gets darker on the other side, usually when one hid is darker than the other its a sign of a ballast about to go out
I tried switching the bulbs but ended with the same result. I will have to try the ballast on the side that is lighter to see result. Thanks for the advise.
