Flywheel Upgrade
Caedmon7777
2010 Mazdaspeed 3
I was wondering if anyone has heard of Aasco? I called Horsepowerfreaks.com and they said that they are a local company but I have never heard of them. Is 8lbs light? what's the weight of the stock flywheel? what are the pros and cons of a light weight flywheel? Sorry to sound like a noob but just I am cautious.
the stock is around 14 maybe.. your car will rev up faster because there's less mass for the engine to pull.But you may get rought idle. I been told the Asco is pretty good
I have on for dale
I have for sale AASCO flywheel for a 3 gen 1.6 motor with new pilot bearing and friction disc $150 plus S&H. Also have a ACT stage two (six Puck) clutch with new friction disc and throw out bearing for sale $150 plus S&H. Buy both and I'll throw in a Stainless Steel clutch line and I cover the shipping.
47b7d700b3127ccebcb7da12799400000026100AZtGrNk0ct2LA
47b7d736b3127ccebcd9dd68b34b00000036100AZtGrNk0ct2LA
Some pictures of the difference between the Assco and stock 1.6L flywheels other than more free revving and a few more horses across the board no other effect noted other than good stuff. With a six or four puck clutch you can slip the clutch all day to lay down the power and not have to worry about breaking anything and when its time to replace the friction discs it can be done cheaply and quickly compared to a new transmission.
OEM 14lbs vs. Aluminum 6lbs Flywheel
Friction side OEM 14lbs vs. Aluminum 6lbs Flywheel
47b7d736b3127ccebcd9dd4cb36f00000036100AZtGrNk0ct2LA
Back side OEM 14lbs vs. Aluminum 6lbs Flywheel
47b7d736b3127ccebcd9dd2f323c00000036100AZtGrNk0ct2LA
FYI I have tons of 3gen and 1.6L stuff for sale parting out race car click album link in my sig at end of album is pitures of eveything for sale.
Thanks
Thanks
coo thanks
1.6 Turbo setup for sale
Comes all hardware needed?? how much?
I'll include everything you see and new oil lines for the turbo (minus the exhaust flange which I'm selling separate so somebody can make their own 1.6 turbo header). The turbo is a custom Turbonetics T3/4 designed along with the header for the VE of the stock ZM motor spool up start at 2000 rpms. Turbo capable of 24 psi. The Deltagate external wastegate has 10 psi spring in it I'll include 4,6,8 pound springs with spacers and a manual boost controller also has it own down pipe. You'll need to configure your own intercooler pipes and modify the down pipe to mate with your exhaust system as my set up was for modified 1.6 race car. I'll include a some silicone couplers, tbolts clamps, and pipe to assistance in fabing the IC piping. Also included a intake pipe (turbo low pressure side) with an adapter for the MAF sensor is included along with filter. I'll also throw is a set of 440cc WRX injectors. All for $1000.00 free shipping
47b7ce20b3127ccebdf04c40b26300000026100AZtGrNk0ct2LA
47b7d736b3127ccebcd9dfb832aa00000036100AZtGrNk0ct2LA
it's a real good price hey! but i'm gonna sell my pro on a few months so not worth it, i'll let you know if my bro wants it
i might be interested in this setup, do you still have it?
Sure do :)! I have both the turbo set up and the flywheel and clutch. I'm also including with the turbo set up a Snow Performance methanol injection kit. And with the flywheel and clutch if both at brought I'll include a B&M short shifter with Kart-boy bushings and a Stainless Steel Clutch line.
Thanks,
Dave
I'm definitely interested and ready to buy. If you don't sell it to pydpypr I'll take it. Also do you still have the brakes? PM me a list of what you have left please, as I'm looking for other stuff too.
PM sent and yes I still have everything and no serious interests yet.
I can't see all your listed parts for sale at the end of the album. All I see at the end is the car being setup for paint.
Stuff left for sale
Oops sorry they closed Sony Imagestation so now I'm using Shutter fly and there still a bit of a learn curve for me. Check it should be good to go.
Things I left to sale (with links for reference) see album for pics or PM me:
1.Rear Drum to disc brake Wilwood Big Brake kit for min 16" 4X100bolt wheels $500 + shipping
2.Fiber Images 3gen EVO style CF hood with hood pins $200 plus shipping
3. Custom AWR Bilstein Eibach Ground Control coil overs $1100 plus shipping http://www.awrracing.com/store/contents/image.php?image[0]=images/products/protege90-
4. AWR front control arms with spherical bearings special ball joint for bump steer correction $300 for both plus shipping http://www.awrracing.com/store/product_info.php?products_id=157
5. AWR 22mm rear adjustable sway bar $100 plus shipping http://www.awrracing.com/store/product_info.php?cPath=12_2_21_28&products_id=21
6. Indiglo 1.6 Pulley set (Crank Alternator Water) in blue $200 plus shipping http://www.srmotorsports.com/Mazda_Protege_Performance_Power_Pulleys_Parts.html
7. SR Motorsports 1.6 Adjustable cam gears $200 plus shipping http://www.srmotorsports.com/Mazda_Protege_Performance_Engine_Parts.html
8. Custom aluminum intake manifold for 1.6 with custom fuel rail 550cc injectors 6AN fuel lines $100 plus shipping
9. AIM MXL Strada Digital Dash with EGT, Coolant temp, Oil Pressure, Fuel pressure, Speed, and Cylinder head temp sensors $1000 http://www.aimsports.com/products/mxl-strada/index.html
47b7d736b3127ccebcd9d8aaf31300000036100AZtGrNk0ct2LA
Plus a few other item if the sales don't go though.
Thanks
Dave
