GerardPRO5 said:yep.
1. cut the hole out.
2. go to Home Depot, find a piece of drywall that's the same size as the hole
3. buy some drywall tape (or if you want to cheat, the fiberglass kind)
4. put the drywall piece in the hole
5. tape it up
6. spackle it up
7. apply primer
8. paint
next time, don't smash your head against the wall.
you will need some wood to back the corners, unless you cut back to the studs...make sure all sides are square.
mazdadan said:Lots of good advice people have given. Here is an article on the web with pics:
http://www1.diynet.com/diy/wa_drywall/article/0,2037,DIY_14407_2271150,00.html
LOL...someone above said that drywall is expensive....it's like $5 bucks for a 3/8" 4x8 foot sheet at Home Depot. Pretty darn cheap.
mazdadan said:Yeah Home Depot trims it down if you don't need a whole sheet.
Unfortunately here, the Contractor's drywall of choice is 3/8" for most homes. They just slap them up and do a half ass mud job.
Personally when I bought drywall to finish my basement, I got 1/2"
paulmp3 said:werd, i feel 1/2 or 5/8 is easier to work with also. it makes for a much better job. cutting out boxes on 3/8 is like doing surgery. It wants to fall apart so easily.
I did my base ment with 1/2 also. it was just a b**** getting the sheets around the corner and down the stairs. Im lazy so i never finished it, just framed it and rocked it. Its just a room for me to hang out in. It looks better than the ugly block walls.
Around here some of the older house (mass production) use a 2x4 on edge and 1/4" paneling. wanna talk about cheap.
kc5zom said:Why so many basements? Is that a northern thing or something? Not many people in Texas have them.
