First CEL PO455
motomike239
2008 Mazdaspeed 3
last night when i got into my car the check engine light was on, i have 11,236 miles on it and the mods i have are cp-e nano intake, PG turbo inlet pipe and SU test pipe.
Took my car to a shop to get the code and the print out says PO455 EVAP Gross Leak Detected. I just wanted to see if anyone else has had this issue with maybe the same mods before i head down to the dealership and if i should put my stock mid pipe back on before i go?
thanks!
i had that code be4, its a EVAP LEAK. Check ur fuel cap, also tight up the bolts and clamps for ur intake and tip.
