Firing Order help
tazs85rx7
I have a 1985 RX7 with a 4bbl carb.and Im pretty sure the plug wires are in the incorrect place.It also has 2 coil packs. Ive got papers off the net but they only show where 4 of the 6 wires go. It dosent even show which wires are which, just where 4 of them go i dont even konw which wires go to the coils. It has 1 distributer and 2 roters with 4 points on them. Someone please get me a detailed diagram of where all 6 wires go or tell me where I could get one.THANK YOU!!
The distributer cap should be labeled with L1, L2, T1, T2, L, and T. Go look, I'll wait.
Good, now the L stands for leading which are the bottom spark plugs. T stands for trailing which are the top plugs. 1 is the front rotor, 2 is the rear rotor. Make sense?
For the coils, the front coil is for trailing and should connect to the T on the distributer, the rear coil is for the leading.
