Little Beavis
- 2001 MP3-T (#911)
Well, Friday I put the MP3 up on the dyno (see my sig for all the mods).
We did a number of pulls but I took a print out of the 8 psi run and then the last two 12 psi runs (9 runs in total). I could not run any more boost because the stock injectors simply couldn't provide any more fuel and were starting to lean things out even at 12 psi (so my torque was dropping off quicker than it should have).
Anyway 8 psi and 223 hp / 221 ft*lbs and 12 psi with 264 hp and 264 ft*lbs is good enough - especially when you consider the pathetic numbers the stock MSP setup generated (before all the mods).
Here are the plots:
8 psi
12 psi - note the little down "blip" is when I hit the boost limit on my boost controller (it tried to spike to 13 psi I guess).
Here are the plots:
8 psi
