- 96 Miata M-Edition, 2015 Mazda 3 Hatch
So as you all know, I purchased a 96 m edition about a month ago.. Well the last two times I've driven it, I've noticed something odd. I'm not overly concerned because the car runs normally, I just want to figure out what is causing it.
So when I start the car up, things are normal. A few seconds later a rapid squeak will be audible. It isn't constant, and it isn't belt whine. It is a rapid squeak_squeak_squeak. It isn't valve tap, because I've heard that before and that sounds like someone is repeatedly dropping nickels into your engine.
Now the odd part is while the car is in gear or the clutch is fully engaged, this noise will go away...
Your thoughts, miata folk.
