Fender Flares
Tw1g007
2002 Mazda Protege5
I'm sure this topic has come up, but I've started thinking about doing flares on my P5. I know that I'd have to modify universals to fit the rear, was just looking for some information and or guidance. Thanks.
Sent from my ASUS_Z00TD using Tapatalk
I'd also like to know what to do. My car rubs too much over bumps after installing BC coilovers
They will be tough to fit on the rear since there is barely an inch of fender between the wheel well and the door.
From what I have seen, the P5 guys who do run flares, solve the issue with the rear by modifying their rears.
Specifically, if you look up Reg's P5 build thread, he had flares. I dont remember if Circuit does/did, but google will help you. Also search on here, since it HAS been done before.
I've also seen people just cut the flare (so the door isn't affected) and mount it normally. I just don't know how the seal the seam of the cut
Latest posts
