I guess you are going for sound with the CBE part of your mods. The only power gains you will get will be with the DP/RP and those two low flow stock cats.
Best power mod for the buck is the DP/RP upgrade with or without cats, connected to the stock CBE. Saves a lot of money and produces big gain. The stock CBE flows extremely well. I mean better than the flow rate of the exhaust side of the K04 turbo.
You can always mod your CBE later to change the sound the way you want. Or if you want to play with sound now, that's great. Get the sound you want, but don't expect a power gain, because the restrictions are upstream of the CBE.
You can get a little gain by replacing the stock second cat section with a straight through race pipe and no cat and still be legal, but its the combo of three inch DP/RP catless or with high flow cats that will make the other guys get smaller in your rear view mirror. Just one opinion on best use of hard earned bucks.
Oh, and with respect to a good guy with whom I just happen to disagree on this one point, catless DP/RP combo does not, in my experience, cause turbo seal premature leaking. It may contribute to some visible "smoke" under certain circumstances, but that's engine crankcase blow by fumes coming out of the PCV system which goes back into the intake, gets partially burned and then there are no cats to finish off the burn. Oil catch can helps there.
