exhaust question
clos561
how long does it take to remove stock exhaust and instal new or vice versa for dealer trips.? and am i going to need a lift for the exhaust work? or can i jack up the rear and do it like that
It would take a while and I think you would want to weld it on so there are no leaks. Definately not the kind of mod that you are going to switch back to stock to go to the dealer. A catback should not effect your waranty, the dealer may give you some s*** but there is no reason it should ever cause a problem.
ok do you know how i can make a intake upgrade temporary. i was thinking hit up home depot. but i dont kno what to buy
Buy a cpe Cai and you can always switch back to stock in less than 1 hour, the easiest part to put back to stock will be a top mount intercooler, which can be done in about 15 minutes. It may also give you the most benefit. Otherwise just wait for the mazdaspeed parts or the cobb accessport.
