Silver Ecstasy
- 11 MS3 Sport
I'll have to admit - I was always against exhaust on our cars. And I'd fight tooth and nail saying the exhaust was almost 100% to blame for smoking turbos because almost (keyword: ALMOST) everyone who had a DP/RP/CBE (not in any particular order) was eventually posting about a smoking turbo.
I don't drive my car obnoxiously hard, and I have a short trip to work. But summer is near, and I want something that I can enjoy installing and also add a little "character" to the car. Obviously, i'd like to see some performance increase. But maybe that's wishful thinking? That's what i'd like to discuss.
Exhaust Gains on MS3's
It's been said that the 2.5" exhaust on our MS3's are fairly well engineered, with hardly any extreme bends and a pretty appropriate amount of flow for the car. A majority of this evidence has been from magazines and their parts testing, as well as people and their own personal "lack-luster" feedback that the exhaust was a nice mod but had no major gains. It's also been said that a 3" exhaust is really not necessary for our cars unless you're in the 300hp+ range.
Forced Induction and Exhaust
It's been my understanding that exhaust and exhaust backpressure are always a good thing to have when it comes to NA (naturally aspirated/non super/turbocharged cars). However, when it comes to our MS3's being turbo-charged, the rule should technically apply in any level that opening up our exhausts, freeing up flow on the exhaust side of an even greater scale and lowering EGT's will be a beneficial and positive addition to our cars, or ANY turbo car for that matter.
The Debatables
Ultimately, exhaust gains are always subtle and minimal on any car. However, no one has really ever done any hard proof on just how much this improves the car and that seems to add to everyone's doubt that the exhaust is NOT worth it other than just for sound. Let's all be honest, that's technically the #1 motivating factor for purchasing an exhaust system is changing/enhancing the sound anyhow. And the aftermarket exhaust manufacturers will do what they can to squeeze dyno-proven gains out of their exhausts using their specific ingredients combined with their unique sound to capture the minds, hearts, and all-mighty dollars of car enthusiasts.
The other thing I have noticed is there is a significant lack of paper proof when it comes to exhaust modifications. No one has really done a dyno to prove whether or not their hard-earned money has done anything. But what about EGT's?
Technically, a Catalytic O2 temp sensor on the Dashhawk could be a reliable gauge for EGT's right? For example, during normal driving, I hit 1200*F. When I am stepping into the boost or am on the highway, I see 1500*F+. I'd imagine that someone with an aftermarket exhaust could monitor these #'s during their normal commutes and report back?
From my imagination, i'd also bet that a CAI/SRI would also be complimented by a CBE. And a turbo inlet would also be complimented appropriately by a downpipe. Freeing up intake restrictions along with your exhaust. Freeing up restrictions in the inlet (directly attached to the turbo intake), and match it up by freeing up your downpipe (directly attached to the turbo's exhaust). Isn't that decent logic for modding our cars?
Any and all information would be fantastic guys. I think this is something that could be real beneficial to existing and new MS3 owners alike.
Exhaust Options Available
-MAZDASPEED cat-back exhaust
3" exhaust piping
4" polished tip with MAZDASPEED engraving
-HKS Hi-Power cat-back exhaust
2.95" (75mm) exhaust piping
4.5" offset polished tip
-Greddy Ti-C cat-back exhaust
3.14" (80mm) exhaust piping
?" offset with heat-treated tip
-Corksport cat-back exhaust
?" exhaust tip with CS insignia plating
-CPE cat-back exhaust
3" exhaust piping
?" exhaust tip
I know there is GHL, Vibrant, AutoExe, Cobb (discontinued) and Borla but I didn't think those really played a key role in the majority of exhausts purchased.
*EDIT*
Also, got this useful information as well:
The Debatables
3" exhaust piping
3" exhaust piping
?" exhaust tip
*EDIT*
From Tuner Performance Reports - TPRMag.com - Featured Article - The Turbo Exhaust
Objectives of the Turbo Cat-Back
The objective of a properly-engineered, aftermarket cat-back exhaust system is to provide additional performance while still delivering adequate sound control. Unlike an all-motor exhaust system, a turbo exhaust system suffers no ill effects from going as big as possible. Bigger is better in this case. The bigger or larger diameter exhaust pipes allow the back pressure to be significantly less than the factory exhausts system. As a result, the difference in exhaust pressure before and after the turbocharger is increased. The increase in the magnitude of the pressure difference allows the turbocharger to reach higher shaft speeds at lower engine operating rpms. As a result, boost response increases and boost pressures increase. More boost pressure at the intake manifold results more power at the wheels. Can a turbo exhaust be too big? A turbo exhaust is too big if it drags on the ground or is too large to provide adequate sound suppression. For peak performance, most aftermarket turbo exhaust manufacturers will use the largest diameter tubing that can be properly routed underneath the vehicle. A muffler will be matched that allows an adequate amount of sound suppression.
