Velocifero
Wham Bam thank you Ma'am
- VRM MS6, Sunlight Silver MSP
the black wire is ground, and you can either loosen a bolt anywhere down there that is touching the chassis, or you can splice it to another grounded wire. usually they are the black wires, but if you find one you want to use, best to ask if it is alright. I used the ground for my turbo timer so I didn't need to find another spot, but there are plenty to choose from. the hoel that you are going to push the wore to comes out in the engine bay behind the battery against the wall there. you will see the black wire loom from that yellow amp power wire going through it, I can take another picture fo ryou if needed.
