Alright... so I have installed, CP-E Catted Downpipe, CP-E Dual Catback, CP-E CAI, SU Turbosmart BOV, ETS 3.25" TMIC, and recently a prosport boost gauge T'd off the vacuum line to the BOV.
My boost gauge shows peak of 20-22psi then drops down to about 15psi when I go to WOT then drops to 13psi@5800 and settles at 10psi. Also it seems to fluctuate a lot between 3k-5.5k. The needle jumps between 10 and 20psi and doesn't hold a constant reading. Is this a problem of the boost gauge or am I seeing some sort of boost leak? Also, is this typical boost reading for what I have installed or does it seem low? I found a leak between the cold pipe and the TMIC and fixed that but maybe there are more leaks to be found...
Also, I keep getting the CEL P0421 Warm-up catalyst system (RH) efficiency below threshold ON 2 Catalyst. It always pops on on the freeway going around 60 in 6th gear, like 2-3k RPM. Would an exhaust leak at the downpipe cause this code to pop? When I drive it harder the check engine light stays away /shrug.
I waiting on getting the dashhawk so I can datalog but atm school has dwindled my play funds.
Any input/suggestions would be appreciated. Thanks.
edit: ignore confusing thread title
