Excess Pressure could cause valve float...
peepsalot said:
I know our vacuum solenoids are mitsubishi. :D
The alternator on my 81 rx7 is a mitsu as well. So long as the thrust bearings aren't i think we'll be allright.
but damn that new evo 9 is sexy.
well i think your machinist is trying to cover his ass incase he didnt do a good job building the motor. you will only float a valve with old worn out springs, there is no way a fresh set of springs should ever not have enough pressure to do as they please. DSM crank walk is only prevalent in 7bolt 2g motors due to a bad machining of the crank which throws off the thrust bearing alignment...hence why when it happens you can press in your clutch and shove your crank a good half inch into the fender well. been there done that swapped in a 6bolt 1g motor and ran as much boost as I pleased...crank walk has more to do with beefed up pressure plates that it does boost levels....a well built FS series motor should have no problem handling 20-25psi....and yes im aware psi is nothing and I should of stated cfm, but we'll assume its a t3ish size turbo appropriate for the displacement of these motors...with 8:1 compression built motor the last thing on my mind would be something in the motor going...id start thinking about the weak tranny and thin cv shafts that are going to blow at the hp level....
I'm going to just go really really easy on everything on the street, low boost, and then open it up on the track, but keeping the shifting nice and easy, especially in 3rd gear(weak point, middle of the shaft). Other than that it's gonna be hopes and prayers.
