Hey all.
I got this 2.5 years ago used from a dealership with 56k kms on it and I'm up to 108k now. I've kept up to do date with the oil changes. I also replace the cabin air filters every year. I got a new battery 1.5 years ago. Two years ago I got the cracked cylinder head replaced. Just got back from dealer to do the tire swap and had the stabilizer links replaced in the front as they were apparently broken. I could hear clunking for a while. Brake pad levels are still fine.
Anyway, I'm looking at Schedule 2 for Canada here: https://www.mazda.ca/en/digital-owners-manual/2017/cx-9/contents/07020300.html. I see that it says to replace spark plugs at 64k kms. I haven't done that.
On the invoice today it mentions the below recommendations or deferred maintenance. I'm wondering if any of you do these or the spark plugs as mentioned above.
16MAZZALIGN 4 WHEEL ALIGNMENT
PERFORM 4 WHEEL ALIGNMENT. ROAD TESTED TO VERIFY STEERING WHEEL ANGLE,
ALIGNMENT MEASURING HEADS WERE ATTACHED TO EACH WHEEL/RIM ASSEMBLY AND
COMPUTER LASER READER TAKES MEASUREMENTS OF ALL WHEELS AND CALCULATES
ADJUSTMENTS REQUIRED TO RE-ALIGN ALL 4 WHEELS. $159.95 + TAX
16MAZZBRAKEFLUS BRAKE FLUID SERVICE
PERFORM BRAKE FLUID SERVICE - RECOMMENDED EVERY 2 YEARS OR 40,000 KM $169.95 +
TAX
16MAZZDIFF DIFFERENTIAL SERVICE
PERFORM DIFFERENTIAL SERVICE (48,000KM INTERVALS) WITH FULL SYNTHETIC FLUID AS
PER MAZDA SPECIFICATIONS $209.95 + TAX
16MAZZSKYTRAN SKY TRANS SERVICE
SKYACTIVE TRANSMISSION SERVICE $347.95 + TAX
16MAZZTHROTTLE THROTTLE & INTAKE
THROTTLE BODY AND COMBUSTION CHAMBER CLEANING ADDITIONAL PROTECTION WITH AIR
INTAKE CLEANING AND DECARB SERVICE ON ENGINE VALVES $169.95 + TAX
16MAZZTRANSCASE TRANSFER CASE FLUID
TRANSFER CASE FLUID CHANGE $209.95 + TAX
22MAZZ19 DRIVE BELT(S)
cracked & worn, recommend replacing - $ (I had an independent mechanic look at this a few months ago and he said it was fine. Dealer specifically told me during my last tire swap or oil change or whatever that I should replace it. This time for current tire swap they didn't say anything)
30MAZZFUELINJEC MAJOR FUEL/INJECTION
MAJOR FUEL AND INJECTOR CLEANING SERVICE, RECOMMENDED EVERY 56,000KM'S OR
EVERY 2 1/2 YEARS. $169.95 + TAX
TAX
