Hey guys.... getting a CEL from my MAP/Baro sensor. Code is P0106. Wondering if anybody else has gotten this? I have an AEM cold air intake and the MAP sensor is mounted to the side of it. The wiring harness was extended to reach the sensor. I resoldered the connection on that to make sure it was a good connection, checked the prongs in the female connection and everything seems ok. I was wondering if anyone else has gotten this error code before? Did buying a new map sensor fix the problem? Before I go and spend $150 on a new sensor, I want to see if anybody here has had the same code and what they did to fix it. Any help would be greatly appreciated.
