Enkei 18" 18x7 +38
Rawyzf
Contributor
2011 Mazda CX-9 GT AWD
Will these fit you think?
Enkei RS6
18X7
Silver
5:100/114, 38mm offsetPart #: 61002
Yep, 38 is too low. Definitely aim for around +45 and above. Rolling the fender helps a lot too.
FlipandFunk said:
45 to 48mm should be the lowests you should go.
not really the lowest i've seen on a 6 was 42 and i am personally running a 43 offset. of course your rear fenders would have to be rolled...
Now that you mentioned it, I now recall a 6 that has 18x7 Centerline wheels and those wheels are +42 offset. Not sure if the fenders are rolled (they probably are). Good catch.
42 is too low, besides you really need 235's on a ms6 instead of dinky 215 so 42 even with rolled fender is gonna be tough, stay at 48.
The factory offset in the Speed 6 is +55.
The factory wheels are 18x7.
From what I have read just about any 8" wide wheel will require a roll, even if it is high offset like +48. Even the RX-8 wheels are hit and miss. Some people say you need a roll and others don't.
Which is true...
I run a 18x8 RX8 wheel, 50MM offset...
Lets go through my RX8 wheel history...
Silver RX8 wheels - 2005 Mazda6s - 225/45/18 Bridestone Potenzas
Silver RX8 wheels - 2005 Mazda6s - 235/40/18 Falken Azenis
Silver RX8 wheels - 2005 Mazda6s w/ Mazdaspeed Springs - 235/40/18 Falken Azenis
Silver RX8 wheels - 2006 Mazda6i - 225/45/18 Bridestone Potenzas
Silver RX8 wheels - 2006 Mazda6i - 235/40/18 Falken Azenis
Polished RX8 Wheels - 2005 Mazda 6s w/ Mazdaspeed Springs - 235/40/18 Falken Azenis
Polished RX8 Wheels - 2006 Mazda 6i - 235/40/18 Falken Azenis
Polished RX8 Wheels - 2006 Mazdaspeed6 - 235/40/18 Falken Azenis
Never had rubbing, even on the lowered car....
I'll have some AutoEXE "Low Down" springs on soon, we'll see if it rubs then...
