- MP5T / 944
Vent!
This new fuel rail is designed for higher output engines or those who'd like to replace the ugly stock rail. It features 1/2" ID, CNC Billet aluminum brackets, allen head hardware, 2-XRP O-ringed fittings.
rednecks_r_us said:So the plans (dreams) are pull my original motor and swap it with the new (used) motor. Then rebuild my original motor with J-spec intake cam, AWR exhaust cams. Port & polish anything that can. Jet hot or powdercoat anything that can. I'm wanting Oliver Rods and CP Custom Pistons. And ARP 11mm head studs. I also want CP Gold Ring Package, Toga bearings, New oil squirters, New Freeze Plugs, New Oil galley plugs, address the crank walk issuse by having a second thrust bearing machined and installed, then have the crank nitrated a second time, and get micro polished, line honed, square decked, bored, honed, plateaued, & all oil passages chaffered. I'm checking into a 11:1 compression too. I'm wanting to do the VTCS removal and any other cheap mods for 1 or 2 extra ponies as well.
TurfBurn said:CP's come with top shelf (gas nitride, very strong, very good) rings right off the bat... so if you have to "pay" for better rings you are being ripped off. Just want to clarify/double check that.
Crankwalk has yet to be proven in anyway shape or form... and there are cars well over 300 horse which running NA you will not get near... so you are wasting money and potentially upping your risk factor by having the crankwalk "fix" of adding an additional face to the main and weakening it further by taking out material (and the stress it'll induce as I doubt enough can be done to eliminate the stress risers) and the potential of misalignment which leads to other issues. Not to mention the oil passages weren't designed to have to feed double the thrust bearing surface area. If you read about DSM crankwalk and what most believe to be the end result cause of it, it is due to a lack of proper oiling because mistubishi's oil squirters allowed pressure to drop enough such that not enough oiling was present on the thrust bearings and this causes bearing crash that wears out the thrust face and the end result is crankwalk for them...
Our cranks are ridiculously strong as is... so having it nitrided at all, especially you staying NA isn't at all necessary.
TurfBurn said:what was your "really good price" As most of us are paying 700 or less for a full long block with cams and head and everything... Plenty of people getting blocks SHIPPED for around 400-500.
rednecks_r_us said:Thanks for the info. I am just starting the research stages and am eager to learn all that I can befoe buying anything
rednecks_r_us said:To be fair to MAM I'm not going to post the price. Beau sponsor Arizona Mazda Club and gives some nice deals when he can. This was one of those nice deals.
This wasn't just a block it is a complete engine
TurfBurn said:Then read my thread called A Rebuild Story: A Forged MP3 that has everything you need to know in it and all the whys and whats.
TurfBurn said:Here is the rebuild thread:
http://www.msprotege.com/forum/showthread.php?t=83298&highlight=MP3+rebuild+story
