My fiance has a 2002 protege and ive been trying to find some ways to improve the car. She bought it used a few years ago and doesnt know the maint. history. So with that said i was going to try to change some of the easy stuff if i could.
All i have changed so far are the sparkplugs, battery/terminals and the air filter. The plugs looked terrible. The gap was close to .095 on a couple of them but the others werent worn near as much. I would hope they would have changed them all at the same time but who knows. They were also pretty frosty. She had the belts changed last year or the year before that. The one in front (larger one) looks good but the smaller one running with the alternator has some cracks on the ribs. One of them is also squeeling some when she starts the car.
The car has about 120k on it if i remember right and is a 2.0L. I want to change the brakes as they are making noise now too but havent ever attempted that before. The timing belt and water pump from what ive read may need to be replaced as well. I havent ever changed either of those on anything either. I did give the walkthrough on the timing belt a read though and it doesnt look too bad at first glance.
How much trouble can i get into trying to change the timing belt myself? How about the water pump or the brakes for that matter. If i knew the process was pretty straight forward i wouldnt mind giving it a try but dontt want to cause issues either. Especially when its my fiances car. If it were mine i may be more inclined to jump in.
From what ive read to replace the 2 belts (not timing) is a matter of loosening three screws correct? How do i know the right belt tension when im reinstalling it?
So with all that said can all give me some direction or some pointers on what to do?
Thanks,
Major
Thanks,
Major
