Engine-Tran Mounts Part Numbers?
Can someone help out? I need the part numbers for all of the mounts.
I think there are three mounts but am not sure. I need to replace all of them.
Thanks!
Mount # 1TDY0-39-04X $ 118.30 Mount # 3 TD84-39-06Y # 85.37 and the trans mount TD11-39-070C $ 91.67. This info is from tasca parts. I don't know if you need the brackets. Those are separate from the mounts.
If your brackets are still good then you don't need them. You are the only one that can determine that. Also can you tell me how did you know your mounts are bad? what are the symptoms or signs of bad mounts. Thanks in advance for any info you can give me also how many miles do you have on the 0
Sure. The car is at about 137,000 miles. I did the spark plugs at 70,000 so its due.
I am gearing up to do the plugs, coolant, struts, and engine mounts.
I know at least one of the engine mounts are gone since the engine is normally very smooth and now it hobbles and shakes around randomly when I am in reverse, or going forward, sometimes it is smooth. I'm not sure if it's one mount or all three but at 137,000 miles, none will likely last too much longer so I am looking at just doing them all unless it is clear which one has gone bad. I have not been successful in examining them.
Are you doing this yourself? if so can you tell me how do you get the cowling off to get to the top nuts for the front struts. Also have you done the belts yet? a few of us are waiting to see if someone does this on their own and how they went about it. Once again thanks in advance for any info that you can provide.
