It will instantly start to detonate in boost.[/QUOTE
YES IF I WAS A RETARD AND RAN 91 OCTANE GAS I WOULD BE ******. I AM RUNNING 94 AND HAVE METHENOL INJECTION, COLDER PLUGS AND LESS BACKPRESSURE. MORE THEN ENOUGH TO KEEP DETONATION AWAY AT 8PSI.
3.Especially on stock ignition timing.
Should be fine at 8psi. If its not, ill back it to 6psi until I get the J and S.
4.there is one thing we have all learned, its that the MSP breaks when it wants to.
this is the stupisest thing you have ever said. Maybe people who dont know what the **** they are doing, maybe you are one of them.
yashart@work said:There is no such thing as high and low boost with high compression pistons. There is NO boost with high compression pistons. Period!
Jeff, have you thought about port matching the intake manifold and head? I don't know how much material you can take out of the exhaust manifold and ports, but the intake side can defiantely be opened up. I know you mentioned porting the exhaust manifold earlier in the thread. Let me know what you end up porting
This is where you are wrong, there have been cases of the msp blowing up at STOCK BOOST. 150 hp, 100 under what your stating your running
jeffmsp said:Sorry For Being A Bastard And Bashing People, But This Weak Rod bulls*** Stops Here. Unless Someone Can Show Me Evidence Of Someone Breaking A Rod At Less Than 250whp Properly Tuned With Supporting Mods Then Just Stop The Internet bulls***. Blkzoomzoom Made 200 Qm Passes Between 270-290whp Estimate, I Ran 14psi For 3 Years 100,00kms No Problems. Just Cause You People Dont Know s*** About Modding Your Car Doesnt Mean The Rods Cant Hold 250 Or Less. No More bulls*** Show Me Evidence Or Stfu.
jeffmsp said:going to the leave the intake manifold for now, should not be holding me back as the fsze is the best fs IM you can get, if I ever take it apart ya I would port match.
low_psi said:Blake, he's going to have to be careful with the boost level, but methanol injection is a big key here. Maybe I will do the calcs later today to compare effective compression between the DE and ZE pistons at various boost levels. I'm interested to see how they compare.
